By dayzman
#18767 I have this simple piece of code that somehow triggers the watchdog to reset continuously:
Code: Select allstatic ETSTimer testTimer1;
void user_init(void)
   // Configure the UART
   uart_init(BIT_RATE_115200, BIT_RATE_115200);
   os_timer_disarm(&testTimer1);
   os_timer_arm(&testTimer1, 1000, 1);
The timer shouldn't freeze up the device, so why does the watchdog keep resetting it continuously?
Thanks
By BarryP
#18774 I reported the timer bug a while ago .
the latest SDK v1.1.0 has made the bug worse .
Edit: missed the main reason your problem ....
gotta set a callback .
void testTimer1_cb(void *arg){
// do something
    os_timer_setfn(&testTimer1, (os_timer_func_t *)testTimer1_cb, NULL);
