By HermannSW
#18963 Hi,
I had problems in flashing ESP8266-01 from Arduino IDE and got help on Github:
https://github.com/esp8266/Arduino/issu ... -106367956
I knew that CH_PD and VCC had to be connected to VC of USB2TTL before, and learned there that RESET has to be connected to VC as well.
Based on that knowledge I soldered a stand for ESP8266-01 that has bottom 9 female pins for connecting coin cell connector, horizontal 2x6 female (for connecting ESP8266-01 in the middle 2x4 and top 6pin female providing all 6 variable connections [TXD/GND/GPIO2/GPIO0/RXD/VCC(=RST=CH_PD)].
After I learned that coin cells cannot provide the current needed by ESP8266-01 I added another connector fitting into the bottom 9pin connector and being plugged directly into 3.7V LiPO. With that I got nice "Standalone small outdoor #Wifi #access #point and #webserver":
https://twitter.com/HermannSW/status/604621715554091008
My question now is whether the 6pin 1line connector layout at top is good?
Seems to provide everything needed (even setting GPIO0 to GND for flashing).
Hermann.
By GeorgeIoak
#19079
HermannSW wrote:My question now is whether the 6pin 1line connector layout at top is good?
I'm sorry but what is your question, can you please clarify?
By HermannSW
#19097 > I'm sorry but what is your question, can you please clarify?
I just wanted to ask whether providing only 6 PINs because always VCC(=RST=CH_PD) as far as I know is a good idea and having the connector do that (always)?
Otherwise additional wiring for VCC (and GND for flashing) is needed like here:
The typical "run" scenario looks like this, VCC and GND from bottom/left, 6 pins for applications on top/right:
The on/off switch originally intended to power ESP8266-01 on and off has an additional use, it allows to switch easily between flash and run mode with just one additional cable between bottom/left GND and GPIO0 via USB2TTL:
Just inserting 6 single pins into the 6x1 female connector allows to just plug it into a breadboard (which 2x4 original layout does not allow for):
I am not good at soldering, but the connector works fine (although I probably used too much solder):
The bottom 9x1 pin female connector at bottom was motivated by just plugging in cell coin connector:
But I learned later that the 3mA a CR2032 can provide do not suffice for the 25(75)mA an ESP8266-01 needs even without(with) Wifi.
Just made use of the until now unneeded cell coin connector as pluggable connector stand with battery clip soldered:
Hermann.
By GeorgeIoak
#19135 It is not a good idea to directly connect RST to VCC. If you ever use code or try to reset the module you will get a short between VCC and ground. The same is true for CH_PD although most people don't disable the module. If you do connect this to another MCU (like an Arduino) you could use the CH_PD pin to reduce the current consumption of the ESP to almost nothing so for safety it always better to use resistors.
The pull-up resistor value is not critical but typically a value of ~10k is used.
