By OnlineDishwasher
#34109 I'd like to get into IoT and play with the ESP8266 and I thought an easy intro would be to make an RGB LED strip controller. I'm much more comfortable with software than hardware and would like feedback on my overall plan.
I found this: http://www.esp8266color.com/hardware/ and plan on buying the following hardware:
- RGB LED strip (already own a 5M one)
- 12V 2A AC adapter (already own one)
- ESP12E with board (http://www.aliexpress.com/item/new-esp8 ... 25397.html)
- 3x IRLZ44NPBF MOSFETs (http://www.aliexpress.com/item/TECHCODE ... 81143.html)
- Power jack (http://www.aliexpress.com/item/20PCS-LO ... 82652.html)
- RGB LED strip connector (will salvage from current controller)
- 6x 10kΩ resistor (already have some)
- 4x switches (already have some)
The project linked above uses the Soulis framework and an Android app but I'd like to write my own software for the ESP so as to expose a RESTful API only and use it with a custom web app.
Here are the endpoints I imagined:
- set the color with POST /color with RGB color HEX code
- get current color with GET /color
- set the color presets with POST /preset1 or /preset2 and a HEX code
- get the color presets with GET /preset1 or /preset2
- turn it on with GET /on
- turn it off with GET /off
- get wifi settings with GET/settings
- set wifi settings with POST /settings (AP, password)
I would also like to have a reset button to restore the default settings on the device and restart it, a button to turn it on/off, and two buttons to change the light to two preset colors.
I'm assuming that I should use a resistor for each switch and connect each switch to a GPIO, triggering the corresponding action when the circuit is closed.
So the circuit for each button would be something like GPIO pin -> switch -> 220Ω resistor -> ground. Is that right?
For the initial state with the default config, I was thinking of making the ESP an AP so that a device can connect to it and POST to the /settings endpoint to set the SSID and password, after which the unit will reset and connect to the wifi.I'd like to avoid hardcoding SSID and password so it's easier to change without reflashing if the controller is in a hard to reach place. Is that the conventional way of doing it?
I plan on using one of these boards: http://www.aliexpress.com/item/5pcs-6x8 ... 18256.html.
A few hardware questions: - What kind of soldering iron tips do I need to be using for smaller things like the ESP12's pins? Right now I have the screwdriver one my Weller WLC100 came with, it looks too large to to do that kind of soldering. - Did I overlook anything?
I know that's a lot of questions, this is all new to me and I'm excited to bridge hardware + software!
By Touliloup
#34190
OnlineDishwasher wrote:I found this: http://www.esp8266color.com/hardware/ and plan on buying the following hardware:
Awesome website you found there (ok it's mine, but still ^^)
OnlineDishwasher wrote:- RGB LED strip (already own a 5M one)
2A with all the led ON will power less than 2 meter, so limit the power via software, use less LED or find a more powerfull adapter!
The rules is usually 0,6A per meter for the 30LED/m strip and 1,2A per meter for the 60LED/m strip. Don't forget that the esp will use a tiny bit of power and it's better to not get too close to the maximal capacity of the transformer, by using an oversized adapter you'll increase his duration.
https://learn.adafruit.com/rgb-led-strips/current-draw
OnlineDishwasher wrote:- ESP12E with board (http://www.aliexpress.com/item/new-esp8 ... 25397.html)
Don't hesitate to take several board, it doesn't always work the first time in electronic and you don't want to wait 1month every time... save you some trouble and order 3-5 of them.
OnlineDishwasher wrote:For the initial state with the default config, I was thinking of making the ESP an AP so that a device can connect to it and POST to the /settings endpoint to set the SSID and password, after which the unit will reset and connect to the wifi.I'd like to avoid hardcoding SSID and password so it's easier to change without reflashing if the controller is in a hard to reach place. Is that the conventional way of doing it?
Yes and you'll find an example project here to start with:
viewtopic.php?f=29&t=4060
OnlineDishwasher wrote:I plan on using one of these boards: http://www.aliexpress.com/item/5pcs-6x8 ... 18256.html.
Those board are convenient for prototype but they quickly become a mess... the project on esp8266color was also started on such prototyping board. So no reason that it doesn't work.
OnlineDishwasher wrote:A few hardware questions: - What kind of soldering iron tips do I need to be using for smaller things like the ESP12's pins? Right now I have the screwdriver one my Weller WLC100 came with, it looks too large to to do that kind of soldering.
Yes if you can use lower power/thinner tip, you should do so. The goal is to make a clean solder and keep those board from overheating.
By GengusKahn
#34354 Hi there, there is a lot of code already available in the Arduino IDE connected to Pixels see the sketch below to control via routines and flags.
This is a modification of the Example sketch......Be careful of the Police Strobe...Photo sensitive epilepsy warning and all that...........
3 ESP's 200 LED's
Code: Select all////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
//        150KB free Sketch Space 31 KB free Memory and Untouched SPIFFS........
// This is a demonstration on how to use an input device & webpage to trigger changes on your neo pixels.
// You should wire a momentary push button to connect from ground to a digital IO pin(use the flash button).
// When you press the button it will change to a new pixel animation. Note that you need to press the
// button once or trigger from webpage to start the first animation!
#include "FS.h"
#include <Adafruit_NeoPixel.h>
const char* host = "EM-Pixels";
IPAddress apIP(192, 168, 4, 1);
WiFiServer server(80);
WiFiClient client;
extern "C"
#include "user_interface.h"
ADC_MODE(ADC_VCC);     //   !!*!*!*!*! DO NOT USE THIS IF LDR FITTED !*!*!*!*!*!!
int wloop=5;
char tDigit;
String TiMeS,TMnow,MyNtP;                            // The current TimeStamp from Google....
int tIMeh,tIMem,tIMes,newt,newt1,inChar,SCsa,MNsa,HRsa;
boolean got_text = false;   //Print the Text to LCD if true......
int hr,mn,st,st1;  // Uptime Duration Counter......
String DsTable;             //Discarded parts if the Strings......
String tmtxt1,tmtxt2,DisTeXt0,DisTeXt1;              //Strings from the Web....
String theDate,theDate1,duration1,theDateTr;             // The current TimeStamp Date from Google....
unsigned long ulMeasCount=0;                         // values already measured
unsigned long ulMeasDelta_ms;                        // distance to next meas time
unsigned long ulNextMeas_ms;                         // next meas time
unsigned long ulReqcount;                            // how often has a valid page been requested
unsigned long ulReconncount;                         // how often did we connect to WiFi
// The Flash Button fitted to GPIO 0 on most development modules can be used.
#define BUTTON_PIN   0    // Digital IO pin connected to the button.  This will be
                          // driven with a pull-up resistor so the switch should
                          // pull the pin to ground momentarily.  On a high -> low
                          // transition the button press logic will execute.
#define PIXEL_PIN    12    // Digital IO pin connected to the NeoPixels.
#define PIXEL_COUNT 40
// Parameter 1 = number of pixels in strip,  neopixel stick has 8
// Parameter 2 = pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
//   NEO_RGB     Pixels are wired for RGB bitstream
//   NEO_GRB     Pixels are wired for GRB bitstream, correct for neopixel stick
//   NEO_KHZ400  400 KHz bitstream (e.g. FLORA pixels)
//   NEO_KHZ800  800 KHz bitstream (e.g. High Density LED strip), correct for neopixel stick
Adafruit_NeoPixel strip = Adafruit_NeoPixel(PIXEL_COUNT, PIXEL_PIN, NEO_GRB + NEO_KHZ800);
const int bright = 10;         //select 1 thru 10 ( this is multiplied by 25 to get brightest pixel value (from 0-255)
const int minFlashes = 2;      //inimum number of flashes/cycles of each pattern before generating new number of segments
const int maxFlashes = 8;
int maxBurst = 4;              // number of pattern bursts before inverting within each flash/cycle
const int maxNumberOfSegments = 8;      // Maximum allowable number of segments to be generated
                                        // this also defines size of node[] array below
const int maxWait = maxNumberOfSegments;//maximum delay() time in milliseconds - related to number of segments
int node[maxNumberOfSegments];      // array to hold segment nodes
int numSegments = 2;         // initial number of segments
const int maxTailSize = 7;      // length of light "tail" including lead light
int tailSize = maxTailSize;      // initial tailsize - this will vary below
const int arraySize = maxTailSize + 1;  // zero-indexed array for holding brightness values of colors below, and extra "0" at end
// Array to hold 'r' (RED) color values - Add more values array to lengthen 'tail' of lights
// Last value should be "0" to ensure pixels are turned off appropriately
// Make sure the length of tail correlates to maxNumberOfSegments (*if segment length can be 5 pixels, don't want 7 pixel tail)
int r[arraySize] = {
25*bright, 20*bright, 10*bright, 4*bright, 2*bright, bright, bright, 0};
// Due to logarithmic nature of the human eye, each additional brightness level should be slightly less than half the previous value for best effect.
// green color values - NOT USED HERE -- WILL be utilized in future multi-color version of sketch
//** Remove in future version!
// - BE CAREFUL CHANGIONG THESE - Check for loop containing "strip.setPixelColor" first!
int g[arraySize] = {
// blue color values
int b[arraySize] = {
bool oldState = HIGH;  // Switch
int showType = 0;
bool animate = false;  // Web Button
  WiFi.mode(WIFI_AP);
  WiFi.softAPConfig(apIP, apIP, IPAddress(255, 255, 255, 0));
  WiFi.softAP("Pixels http://192.168.4.1");    // Create WiFi network
  WiFi.begin();
  server.begin();
  pinMode(BUTTON_PIN, INPUT_PULLUP);
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
///////////////////////////////1
void wsysreset()
  //Perform challenge to user before getting here to reboot !!!
  //Make an attempt to send mail or other backup of log files then reboot
    ESP.restart();
// create HTTP 1.1 header
String MakeHTTPHeader(unsigned long ulLength)
  String sHeader;
  sHeader  = F("HTTP/1.1 200 OK\r\nContent-Length: ");
  sHeader += ulLength;
  sHeader += F("\r\nContent-Type: text/html\r\nConnection: close\r\n\r\n");
  return(sHeader);
// make html footer
String MakeHTTPFooter()
  String sResponse;
  sResponse  = F(" ");
  sResponse += F("<BR><BR><FONT SIZE=-1>ESP8266 With 40 WS2812B LED's<BR><FONT SIZE=-2>Compiled Using ver. 1.6.5-1160-gef26c5f, built on Sep 30, 2015</body></html>");
  return(sResponse);
//////////////////////////////////1
  // Get current button state.
  bool newState = digitalRead(BUTTON_PIN);
  // Check if state changed from high to low (button press).
  if ((newState == LOW && oldState == HIGH) || (animate == true)) {
    // Short delay to debounce button.
    delay(2);
    // Check if button is still low after debounce.
    if ((newState == LOW) || (animate == true)) {
      if (newState == LOW){
      showType++;
      if (showType > 9){
        showType=0;
//theaterChase(strip.Color(  0,   0, 127), 50); // Blue
      startShow(showType);
    if (animate == true){
   // Set the last button state to the old state.
      oldState = newState;
////////////////////////////////////////////////////////////////////////2
  if (!client)
    return;
  // Wait until the client sends some data
  unsigned long ultimeout = millis()+250;
  while(!client.available() && (millis()<ultimeout) )
    delay(1);
  if(millis()>ultimeout)
    return;
  String sRequest = client.readStringUntil('\r');
  client.flush();
  // stop client, if request is empty
  if(sRequest=="")
    client.stop();
    return;
  // get path; end of path is either space or ?
  // Syntax is e.g. GET /?show=1234 HTTP/1.1
  String sPath="",sParam="", sCmd="";
  String sGetstart="GET ";
  int iStart,iEndSpace,iEndQuest;
  iStart = sRequest.indexOf(sGetstart);
  if (iStart>=0)
    iStart+=+sGetstart.length();
    iEndSpace = sRequest.indexOf(" ",iStart);
    iEndQuest = sRequest.indexOf("?",iStart);
    // are there parameters?
    if(iEndSpace>0)
      if(iEndQuest>0)
        // there are parameters
        sPath  = sRequest.substring(iStart,iEndQuest);
        sParam = sRequest.substring(iEndQuest,iEndSpace);
      else
        // NO parameters
        sPath  = sRequest.substring(iStart,iEndSpace);
  // format the html response
  String sResponse,sResponse2,sHeader;
   if (sPath.startsWith("/pixel_inputs&LED"))
 if (sPath.startsWith("/pixel_inputs&LED3=0")) {
 showType=0;
 if (TMnow=="false"){
animate = true;
  TMnow="true";
    else if (sPath.startsWith("/pixel_inputs&LED3=1")) {
 showType=1;
animate = true;
    else if (sPath.startsWith("/pixel_inputs&LED3=2")) {
 showType=2;
animate = true;
    else if (sPath.startsWith("/pixel_inputs&LED3=3")) {
 showType=3;
animate = true;
    else if (sPath.startsWith("/pixel_inputs&LED3=4")) {
 showType=4;
animate = true;
    else if (sPath.startsWith("/pixel_inputs&LED3=5")) {
 showType=5;
animate = true;
    else if (sPath.startsWith("/pixel_inputs&LED3=6")) {
 showType=6;
animate = true;
    else if (sPath.startsWith("/pixel_inputs&LED3=7")) {
 showType=7;
animate = true;
    else if (sPath.startsWith("/pixel_inputs&LED3=8")) {
 showType=8;
animate = true;
    else if (sPath.startsWith("/pixel_inputs&LED3=9")) {
showType=9;
animate = true;
    else if (sPath.startsWith("/pixel_inputs&LED3=neenaw")) {
neenaw();
showType=3;
animate = true;
  // format the html page for Pixel Input /
 if(sPath=="/")
    ulReqcount++;
    sResponse  = F("<html>\n<head>\n<title>Webpage NeoPixel Controller</title>\n</head>\n");
    sResponse += F("\n<script>\nfunction GetButton1()\n{\nnocache = \"&nocache=\" + Math.random() * 1000000;\nvar request = new XMLHttpRequest();\nrequest.open(\"GET\", \"pixel_inputs&LED3=0\" + nocache, true);\nrequest.send(null);\n}\nfunction GetButton2()\n{\nnocache = \"&nocache=\" + Math.random() * 1000000;\nvar request = new XMLHttpRequest();\nrequest.open(\"GET\", \"pixel_inputs&LED3=1\" + nocache, true);\nrequest.send(null);\n}\n");
    sResponse += F("\nfunction GetButton3()\n{\n\nnocache = \"&nocache=\" + Math.random() * 1000000;\nvar request = new XMLHttpRequest();\nrequest.open(\"GET\", \"pixel_inputs&LED3=2\" + nocache, true);\nrequest.send(null);\n}\nfunction GetButton4()\n{\nnocache = \"&nocache=\" + Math.random() * 1000000;\nvar request = new XMLHttpRequest();\nrequest.open(\"GET\", \"pixel_inputs&LED3=3\" + nocache, true);\nrequest.send(null);\n}\nfunction GetButton5()\n");
    sResponse += F("{\nnocache = \"&nocache=\" + Math.random() * 1000000;\nvar request = new XMLHttpRequest();\nrequest.open(\"GET\", \"pixel_inputs&LED3=4\" + nocache, true);\nrequest.send(null);\n}\nfunction GetButton6()\n{\nnocache = \"&nocache=\" + Math.random() * 1000000;\nvar request = new XMLHttpRequest();\nrequest.open(\"GET\", \"pixel_inputs&LED3=5\" + nocache, true);\nrequest.send(null);\n}\n");
    sResponse += F("\nfunction GetButton7()\n{\nnocache = \"&nocache=\" + Math.random() * 1000000;\nvar request = new XMLHttpRequest();\nrequest.open(\"GET\", \"pixel_inputs&LED3=6\" + nocache, true);\nrequest.send(null);\n}\nfunction GetButton8()\n{\nnocache = \"&nocache=\" + Math.random() * 1000000;\nvar request = new XMLHttpRequest();\nrequest.open(\"GET\", \"pixel_inputs&LED3=7\" + nocache, true);\nrequest.send(null);\n}\nfunction GetButton9()\n{\nnocache = \"&nocache=\" + Math.random() * 1000000;\nvar request = new XMLHttpRequest();\nrequest.open(\"GET\", \"pixel_inputs&LED3=8\" + nocache, true);\nrequest.send(null);\n}\n");
    sResponse += F("\nfunction GetButton10()\n{\nnocache = \"&nocache=\" + Math.random() * 1000000;\nvar request = new XMLHttpRequest();\nrequest.open(\"GET\", \"pixel_inputs&LED3=9\" + nocache, true);\nrequest.send(null);\n}\n\nfunction GetButton11()\n{\nnocache = \"&nocache=\" + Math.random() * 1000000;\nvar request = new XMLHttpRequest();\nrequest.open(\"GET\", \"pixel_inputs&LED3=neenaw\" + nocache, true);\nrequest.send(null);\n}\n</script>\n<body>\n<h1>NeoPixel Controller<BR>_________________</h1>\n<BR><BR><a href=\"/diag\">Diagnostics Information Page</a><BR>\n<body onload=\"GetESP8266IO()\">\n<h1><FONT SIZE=-1>Choose Animation of LED's</h1>\n<form id=\"txt_form\" name=\"frmText\">\n");
    sResponse2 = F("\n<button type=\"button\" id=\"LED3\" onclick=\"GetButton1()\">Pixels Set to OFF</button><br /><br />\n<button type=\"button\" id=\"LED3\" onclick=\"GetButton2()\">Pixels Red</button><br /><br />\n<button type=\"button\" id=\"LED3\" onclick=\"GetButton3()\">Pixels Green</button><br /><br />\n<button type=\"button\" id=\"LED3\" onclick=\"GetButton4()\">Pixels Blue</button><br /><br />\n<button type=\"button\" id=\"LED3\" onclick=\"GetButton5()\">Pixel Animation 4</button><br /><br />\n<button type=\"button\" id=\"LED3\" onclick=\"GetButton6()\">Pixel Animation 5</button><br />");
    sResponse2 += F("<br />\n<button type=\"button\" id=\"LED3\" onclick=\"GetButton7()\">Police Light</button><br /><br />\n<button type=\"button\" id=\"LED3\" onclick=\"GetButton8()\">Pixel Animation 7</button><br /><br />\n<button type=\"button\" id=\"LED3\" onclick=\"GetButton9()\">Pixel Animation 8</button><br /><br />\n<button type=\"button\" id=\"LED3\" onclick=\"GetButton10()\">Pixel Animation 9</button><br /><br />\n<button type=\"button\" id=\"LED3\" onclick=\"GetButton11()\">Police Strobe !Epilepsy WARNING!</button><br /><br />\n</form>\n<br />\n");
    sResponse2 += F("\n<font color=\"#000000\"><body bgcolor=\"#a0dFfe\"><meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0, user-scalable=yes\"><BR>Animated Neopixels ANY TYPE !<BR>\n</div>\n<div style=\"clear:both;\"></div><p>\n");
    sResponse2 += MakeHTTPFooter().c_str();
        // Send the response to the client
    client.print(MakeHTTPHeader(sResponse.length()+sResponse2.length()).c_str());
    client.print(sResponse);
    client.print(sResponse2);
else if(sPath=="/yfireset")  // When Google time is used this will Sync the C
    ulReqcount++;
                                client.println("HTTP/1.1 200 OK");
                                client.println("Content-Type: text/html");
                                client.println("Connection: close");
                                client.println();
                                client.println("<!DOCTYPE HTML>");
                                client.print("<html><head><title>Webpage NeoPixel Controller</title></head><body>");
                                client.print("<font color=\"#000000\"><body bgcolor=\"#a0dFfe\">");
                                client.print("<meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0, user-scalable=yes\">");
                                client.print("<h1>Webpage NeoPixel Controller<BR>WiFi Reset Page </h1><BR><a href=\"/graphic2\">Pressure Graph Page</a><BR><a href=\"/pressure\">Pressure Gauge Page</a>");
                                client.print("<BR><a href=\"/monitor\">Sensor Gauges Page</a><BR><a href=\"/graphic\">Sensor Graph Page</a><BR><a href=\"/table\">Sensor Datalog Page</a><BR><BR><BR><BR>Restarted WiFiConnections = ");
                                client.print(ulReconncount);
                                client.print("<BR><FONT SIZE=-2>environmental.monitor.log@gmail.com<BR><FONT SIZE=-2>ESP8266 With DHT11 & BMP180 Sensors<BR>");
                                client.print("<FONT SIZE=-2>Compiled Using ver. 1.6.5-1160-gef26c5f, built on Sep 30, 2015<BR>");
                                client.println("<IMG SRC=\"https://raw.githubusercontent.com/genguskahn/ESP8266-For-DUMMIES/master/SoC/DimmerDocs/organicw.gif\" WIDTH=\"250\" HEIGHT=\"151\" BORDER=\"1\"></body></html>");
  //WiFiStart();
  else if(sPath=="/diag")
     float   servolt1 = ESP.getVcc();
     long int spdcount = ESP.getCycleCount();
     delay(1);
     long int spdcount1 = ESP.getCycleCount();
     long int speedcnt = spdcount1-spdcount;
     FlashMode_t ideMode = ESP.getFlashChipMode();
     ulReqcount++;
                                String duration1 = " ";
                                int hr,mn,st;
                                st = millis() / 1000;
                                mn = st / 60;
                                hr = st / 3600;
                                st = st - mn * 60;
                                mn = mn - hr * 60;
                                if (hr<10) {duration1 += ("0");}
                                duration1 += (hr);
                                duration1 += (":");
                                if (mn<10) {duration1 += ("0");}
                                duration1 += (mn);
                                duration1 += (":");
                                if (st<10) {duration1 += ("0");}
                                duration1 += (st);
                                client.println();
                                client.print("<h1>Neopixel Control<BR>SDK Diagnostic Information</h1>");
                                client.print("<BR><a href=\"/\">Pixel Control Page</a><BR>");
                               String diagdat="";
                              //  diagdat+=ulReconncount;
                                diagdat+="<BR>  Web Page Requests = ";
                                diagdat+=ulReqcount;
                                diagdat+="<BR>  WiFi AP Hostname = ";
                                diagdat+=host;
                                diagdat+="<BR>  Free RAM = ";
                                client.print(diagdat);
                                client.print((uint32_t)system_get_free_heap_size()/1024);
                               // diagdat=" KBytes<BR>  Logged Sample Count = ";
                               // diagdat+=ulMeasCount;
                                diagdat=" KBytes<BR>  SDK Version = ";
                                diagdat+=ESP.getSdkVersion();
                                diagdat+="<BR>  Boot Version = ";
                                diagdat+=ESP.getBootVersion();
                                diagdat+="<BR>  Free Sketch Space  = ";
                                diagdat+=ESP.getFreeSketchSpace()/1024;
                                diagdat+=" KBytes<BR>  Sketch Size  = ";
                                diagdat+=ESP.getSketchSize()/1024;
                                diagdat+=" KBytes<BR>";
                                client.printf("  Flash Chip id = %08X\n", ESP.getFlashChipId());
                                client.print("<BR>");
                                client.printf("  Flash Chip Mode = %s\n", (ideMode == FM_QIO ? "QIO" : ideMode == FM_QOUT ? "QOUT" : ideMode == FM_DIO ? "DIO" : ideMode == FM_DOUT ? "DOUT" : "UNKNOWN"));
                                diagdat="<BR>  Flash Size By ID = ";
                                diagdat+=ESP.getFlashChipRealSize()/1024;
                                diagdat+=" KBytes<BR>  Flash Size (IDE) = ";
                                diagdat+=ESP.getFlashChipSize()/1024;
                                diagdat+=" KBytes<BR>  Flash Speed = ";
                                diagdat+=ESP.getFlashChipSpeed()/1000000;
                                diagdat+=" MHz<BR>  ESP8266 CPU Speed = ";
                                diagdat+=ESP.getCpuFreqMHz();
                                diagdat+=" MHz<BR>";
                                client.printf("  ESP8266 Chip id = %08X\n", ESP.getChipId());
                                diagdat="<BR>  System Instruction Cycles Per Second = ";
                                diagdat+=speedcnt*1000;
                                diagdat+="<BR>  Last System Restart Reason = ";
                                diagdat+=ESP.getResetInfo();
                                diagdat+="<BR>  System VCC = ";
                                diagdat+=servolt1/1000, 3;
                                diagdat+=" V <BR>  Datalog File Size in Bytes = N/A";
                                //diagdat+=Dfsize;
                                diagdat+="<BR>  System Uptime =";
                                diagdat+=duration1;
                                client.print("<BR><FONT SIZE=-2>environmental.monitor.log@gmail.com<BR><FONT SIZE=-2>ESP8266 With 40 WS2812B 5050 LED's<BR><FONT SIZE=-2>Compiled Using ver. 1.6.5-1160-gef26c5f, built on Sep 30, 2015<BR>");
                                diagdat = "";
                                duration1 = "";
   else if(sPath=="/srestart")
                                client.println();
                                client.print("<h1>Environment Monitor<BR>Please wait 10 Seconds......<BR><FONT SIZE=+2>System Reset Page !!!! </h1><BR><a href=\"/graphic2\">Pressure Graph Page</a><BR><a href=\"/pressure\">Pressure Gauge Page</a>");
                                client.print("<BR><a href=\"/monitor\">Sensor Gauges Page</a><BR><a href=\"/graphic\">Sensor Graph Page</a><BR><a href=\"/table\">Sensor Datalog Page</a><BR><a href=\"/diag\">Diagnostics Information Page</a><BR><a href=\"/\">Monitor LCD Text Input Page</a><BR><BR><BR><BR>Restarted WiFiConnections = ");
                                client.print("<BR><BR><BR><FONT SIZE=-2>environmental.monitor.log@gmail.com<BR><FONT SIZE=-2>ESP8266 With DHT11 & BMP180 Sensors<BR>");
client.stop();
wsysreset();
  else
// 404 for non-matching path
    sResponse="<html><head><title>404 Not Found</title></head><body><h1>Not Found</h1><p>The requested URL was not found on this server, What did you sk for?.</p></body></html>";
    ulReqcount++;
    sHeader  = F("HTTP/1.1 404 Not found\r\nContent-Length: ");
    sHeader += sResponse.length();
    client.print(sHeader);
  // and stop the client
  client.stop();
void colorWipe1(int R, int G, int B, int wait)
   for (boolean inversePattern = 0; inversePattern <=1; inversePattern++)            // Alternates each segment between Red & Blue
      for (int burst = 0 ; burst <= maxBurst ; burst++)                        // Let's run through a few times before inverting color (red/blue)
         //    Run lights starting from pixel 0
         for (int segment = numSegments-1; segment >= 0; segment--)      // Example (2 segments -> segment=0, segment=1)
         // for (int segment = 0; segment < numSegments; segment++)      // Example (2 segments -> segment=0, segment=1)
            // to set pixel colors in each segment
            for (int pixel = node[segment]; pixel < node[segment+1]; pixel++)    // Example (2 segments -> pixel=0, pixel=15 && pixel=15, pixel=30)
               boolean Blue;                              // Will the segment be BLUE? ... or RED?  ... let's find out!
               if (inversePattern == 1)
                  //  if odd, Blue
                  if((segment%2)!=0)  Blue = true;
                  //  if even, Red
                  else if ((segment%2)==0)  Blue = false;
               }    // end if (inverse...
               else if (inversePattern == 0)
                  //  if odd, Blue
                  if((segment%2)!=0)  Blue = false;
                  //  if even, Red
                  else if ((segment%2)==0)  Blue = true;
               }    // end if (!inverse....
               for (int tailPosition = 0; tailPosition <= tailSize; tailPosition++)      // Pixels within each segment
                  if (!Blue)
                     strip.setPixelColor(pixel-tailPosition, (r[tailPosition]), (g[tailSize]), (b[tailSize]));    // Red ONLY
                  }    // end if Red...
                  if (Blue)
                     strip.setPixelColor(pixel-tailPosition, (r[tailSize]), (g[tailSize]), (b[tailPosition]));    // Blue ONLY
                  }    // end if Blue...
               }    // end for (int tailPosition...
               strip.show();
               delay(wait);
            }    // end for (int pixel...
         }    // end for (int segment...
         // Now, shrink the tail....
         for(int p = 1; p <= tailSize; p++)
            for(int t = (strip.numPixels()-tailSize); t < (strip.numPixels()); t++)
               int v = ((strip.numPixels()-t)+p);
               if (v > tailSize) v = tailSize;
               strip.setPixelColor(t, (r[v]), (g[v]), (b[v]));
            strip.show();
            delay(wait);
            // No delay() here. It causes too long of a pause at ends of strip.
         delay(wait);
         //    Run lights back towards 0
         //     for (int segment = (numSegments-1); segment >= 0; segment--)      // Example (2 segments -> segment=0, segment=1)
            for (int pixel = node[segment+1]; pixel > node[segment]; pixel--)    // Example (2 segments -> pixel=0, pixel=15 && pixel=15, pixel=30)
               boolean Blue;
                  //  if odd, Blue
                  //  if even, Red
                  //  if odd, Blue
                  //  if even, Red
               for (int tailPosition = tailSize; tailPosition >= 0; tailPosition--)      // Pixels within each segment
                  if (!Blue)
                     strip.setPixelColor(pixel+tailPosition, (r[tailPosition]), (g[tailSize]), (b[tailSize]));    // Red ONLY
                  }    // end if Red...
                  if (Blue)
                     strip.setPixelColor(pixel+tailPosition, (r[tailSize]), (g[tailSize]), (b[tailPosition]));    // Blue ONLY
                  }    // end if Blue...
               strip.show();
               // delay(wait);
            for(int t = (tailSize); t < 0; t++)
               int v = (t+p);
            strip.show();
            delay(wait);
}  // end void colorWipe1()
void neenaw(){
 int flash = random(minFlashes, maxFlashes);
 // Pick new number of segments
 numSegments = random(2, maxNumberOfSegments);   // Randomly choose how many segments in bar
 int wait = random(0,numSegments)/3;
 maxBurst = random(3, numSegments);
 // defining node (end pixels of segments) from number of segments defined
 for (int i = 0; i <= numSegments; i++)
    node[i] = (i * (strip.numPixels() / numSegments));
 }    // end for  - numSegments - node array
 constrain (tailSize, 0, ((strip.numPixels() / numSegments)-1));
 for ( flash = 0 ; flash <= maxFlashes ; flash++)
    colorWipe1(r[0], g[0], b[0], wait);
 delay(20);
void startShow(int i) {
  switch(i){
    case 0: colorWipe(strip.Color(0, 0, 0), 50);    // Black/off
            animate = false;
            break;
    case 1: colorWipe(strip.Color(255, 0, 0), 50);  // Red
            break;
    case 2: colorWipe(strip.Color(0, 255, 0), 50);  // Green
            break;
    case 3: colorWipe(strip.Color(0, 0, 255), 50);  // Blue
            break;
    case 4: theaterChase(strip.Color(127, 127, 127), 50); // White
            break;
    case 5: theaterChase(strip.Color(127,   0,   0), 50); // Red
            break;
    case 6: theaterChase(strip.Color(  0,   0, 127), 50); // Blue
            break;
    case 7: rainbow(20);
            break;
    case 8: rainbowCycle(20);
            break;
    case 9: theaterChaseRainbow(50);
            break;
// Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint8_t wait) {
  for(uint16_t i=0; i<strip.numPixels(); i++) {
    strip.setPixelColor(i, c);
    strip.show();
    delay(wait);
void rainbow(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256; j++) {
    for(i=0; i<strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel((i+j) & 255));
    strip.show();
    delay(wait);
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
    for(i=0; i< strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
    strip.show();
    delay(wait);
//Theatre-style crawling lights.
void theaterChase(uint32_t c, uint8_t wait) {
  for (int j=0; j<10; j++) {  //do 10 cycles of chasing
    for (int q=0; q < 3; q++) {
      for (int i=0; i < strip.numPixels(); i=i+3) {
        strip.setPixelColor(i+q, c);    //turn every third pixel on
      strip.show();
      delay(wait);
        strip.setPixelColor(i+q, 0);        //turn every third pixel off
//Theatre-style crawling lights with rainbow effect
void theaterChaseRainbow(uint8_t wait) {
  for (int j=0; j < 256; j++) {     // cycle all 256 colors in the wheel
        strip.setPixelColor(i+q, Wheel( (i+j) % 255));    //turn every third pixel on
      strip.show();
      delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
  WheelPos = 255 - WheelPos;
  if(WheelPos < 85) {
    return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  if(WheelPos < 170) {
    WheelPos -= 85;
    return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
  WheelPos -= 170;
  return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
