I am using a very basic script from IDE examples, but I can't get 3.3V (HIGH) voltage on the pin!
The same pin works OK as data pin for DHT22.
Module is ESP-12E, Arduino IDE 1.6.5
Explore... Chat... Share...
> gpio.mode(4,gpio.OUTPUT)
> gpio.write(4,gpio.LOW)
