So i am trying to connect Arduino and Esp8266 through I2c.
On ESP8266 i have connected pins(5, 14)
On Arduino i have connected pins (A4, A5)
Between them i used Logic Level Shifter(also connected ground and 3.3V and 5V).
Now the simple code example:
ESP8266 Master:
#include <Wire.h>
int x = 0;
// Start the I2C Bus as Master
Wire.begin(5,14);
Wire.beginTransmission(9); // transmit to device #8
Wire.write("x is "); // sends five bytes
Wire.write(x); // sends one byte
Wire.endTransmission(); // stop transmitting
Serial.println(x);
x++;
Arduino Slave
#include <Wire.h>
void setup()
Wire.begin(9); // join i2c bus with address #8
Wire.onReceive(receiveEvent); // register event
Serial.begin(9600); // start serial for output
void loop()
delay(100);
// function that executes whenever data is received from master
// this function is registered as an event, see setup()
void receiveEvent(int howMany)
while (1 < Wire.available()) // loop through all but the last
char c = Wire.read(); // receive byte as a character
Serial.print(c); // print the character
int x = Wire.read(); // receive byte as an integer
Serial.println(x); // print the integer
PROBLEM :
Serial Monitor on Arduino is empty(not showing C or X value). Serial Monitor on ESP is showing X value.
Is something wrong with bound rate on Arduino? What am i missing here?
