By Karstonn
#42485
martinayotte wrote:Effectively, but SD-D1 is required to access the flash in both DIO and QIO mode. The only way to free up the pin would be that have the flash in SIO (single i/o with SD-D0), which I doubt we can.
Thanks for that info.
(To that: is the external flash memory needed, or does the chip have some onboard mem, and if how much?)
I think I will have to read a lot more about the flash interface (and the chip as a whole)
Can you point me to some good reading for that, apart from the obvious (datasheet, Espressiv-HP, here) ?
