Due to quality and reliability concerns from the most well-known ESP module vendor, my company has decided to design their own WIFI module using the ESP8266 chip.
As we know, most people update the firmware via a bootloader, but bootloaders usually require a small, pre-programmed section of boot-code in the flash memory to facilitate the operation.
Since the flash chips will be new (and empty) upon manufacture, getting our custom firmware into the flash is the challenge.
I have a few ideas here - can someone please advise me which method is the best:
* Create a separate pin header multiplexed with the flash memory pins, to allow the flash memory to be programmed "in situ"?
* Order the flash chips pre-programmed with our custom firmware (perhaps tricky since initial order quantities may not justify this)?
* Perhaps I have totally misunderstood the ESP8266 chip, and the bootloader logic is actually contained in the SOC itself, so we can bootload firmware to an empty flash chip?
Any advice appreciated
