- Mon Jun 20, 2016 12:17 am
#49462
As far as I remember, KY-003 module is based on a Allegro A3144 hall effect sensor that has a working voltage of about 4.5V-24V, will not work directly on 3.3V, you need a voltage level translator.
A3144 has :
- Operate point (G) - 35 to 450
- Release point (G) - 25 to 430
I don't know if that Hall sensor is sensible ennough to sense the power line switching.
For things like that usually you use a optocoupler or a CT transformer, both more reliable than the hall sensor setup. And If you need only ON/OFF sensing, a simple optocoupler setup will be more than enough.
