I was using NodeMCU 0.9.6 in my ESP-01.
Booting in normal mode I get this (at baud rate 74880)
load 0x40100000, len 28740, room 16
tail 4
chksum 0xcd
load 0x3ffe8000, len 2888, room 4
tail 4
chksum 0xbc
load 0x3ffe8b50, len 15252, room 4
tail 0
chksum 0x4f
csum 0x4f
And booting in flash mode it keeps the Tx LED on and prints endlessly this (baud rate 74880)
Fatal exception (0):
epc1=0x40100000, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
Funny thing is that it boots properly in normal mode and runs the last init.lua I could upload, but it seems to keep busy as it does not show the Lua interpreter prompt, so it ignores any command I send.
---- init.lua ----
print(wifi.sta.getip())
ssid = "asdf"
pass = "asdf"
ipcfg = {ip="192.168.0.23",netmask="255.255.255.0",gateway="192.168.0.1"}
wifi.setmode(wifi.STATION)
wifi.sta.config(ssid,pass)
print("hola")
tmr.alarm(1, 1000, 1, function()
if wifi.sta.setip(ipcfg) == false then
print("Connecting...")
print("hola1")
else
print("hola2")
tmr.stop(1)
print("Connected, IP is "..wifi.sta.getip())
end
end)
dofile("telnet.lua")
-- a simple telnet server
telnet_srv = net.createServer(net.TCP, 180)
telnet_srv:listen(2323, function(socket)
local fifo = {}
local fifo_drained = true
local function sender(c)
if #fifo > 0 then
c:send(table.remove(fifo, 1))
else
fifo_drained = true
end
end
local function s_output(str)
table.insert(fifo, str)
if socket ~= nil and fifo_drained then
fifo_drained = false
sender(socket)
end
end
node.output(s_output, 0) -- re-direct output to function s_ouput.
socket:on("receive", function(c, l)
node.input(l) -- works like pcall(loadstring(l)) but support multiple separate line
end)
socket:on("disconnection", function(c)
node.output(nil) -- un-regist the redirect output function, output goes to serial
end)
socket:on("sent", sender)
print("Welcome to NodeMCU world.")
end)
I've tried reflashing NodeMCU as well as AT 0.9.2.2 with NodeMCU flasher, Esptool, Esp Download tool, Esp downloader, and all of them fail in early communication stage.
Any ideas of how to recover my module?
