By kidi3
#55617 I am at the moment trying to make a stepper motor move with the help of wemos d1 mini.
The arduino interact with the motor through the motor driver. The driver only is given a 5v, step signal, enable signal and direction signal.
According to the datasheet shall these signal be timed as such.
The complete datasheet can be found http://www.sainsmart.com/zen/documents/20-019-201/ST330%20%20Stepper%20Motor%20Driver%20Board%20User%20Manual.pdf
I wrote some code which should comply with the timing which can be seen here
.cpp
Code: Select allvoid stepper_motor::step_pwm()
    digitalWrite(en_pin,HIGH);
    delay(0.005);
    digitalWrite(dir_pin,LOW);
    delay(0.005);
    while(1)
      digitalWrite(step_pin,LOW);
      delay(1);
      digitalWrite(step_pin,HIGH);
      delay(1);
.h
Code: Select all/* Class: stepper_motor
 * Info: contains the setup, and primary interface to control
 * the stepper motor
 * stepper_motor(): constructor -  setup the connection to the control board
 * void step_pwm():  Moves the tilt - uses the bool to determine the direction.
 * bool alive_bool: Is either high (1) or low (0), used for the alive void.
#ifndef stepper_motor_h
#define stepper_motor_h
#include "Arduino.h"
#include "pins_arduino.h"
#define step_pin  D1
#define dir_pin   D2
#define en_pin    D3
#define max_step  200
 class stepper_motor
  public:
    stepper_motor();
    void alive();
    void step_pwm();
  private:
    bool alive_bool;
    bool position_bool;
    int step_count;
#endif
When i execute my program stalls the motor, but when i unplug enable signal begins the motor to spin in one direction, and when i unplug the direction signal spin it the other way. I can't codewise change the direction of the stepper motor, only by either pulling the pin on or off.
This problem seemed to weird to get a hold, which made me think whether it could be due to pin_mapping.h which i use to declare which pin I want to use.
The pin_mapping.h is the one available on github.
Code: Select all/*
  pins_arduino.h - Pin definition functions for Arduino
  Part of Arduino - http://www.arduino.cc/
  Copyright (c) 2007 David A. Mellis
  Modified for ESP8266 platform by Ivan Grokhotkov, 2014-2015.
  This library is free software; you can redistribute it and/or
  modify it under the terms of the GNU Lesser General Public
  License as published by the Free Software Foundation; either
  version 2.1 of the License, or (at your option) any later version.
  This library is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
  Lesser General Public License for more details.
  You should have received a copy of the GNU Lesser General
  Public License along with this library; if not, write to the
  Free Software Foundation, Inc., 59 Temple Place, Suite 330,
  Boston, MA  02111-1307  USA
  $Id: wiring.h 249 2007-02-03 16:52:51Z mellis $
#ifndef Pins_Arduino_h
#define Pins_Arduino_h
#include "../generic/common.h"
static const uint8_t SDA = 4;
static const uint8_t SCL = 5;
static const uint8_t LED_BUILTIN = 2;
static const uint8_t BUILTIN_LED = 2;
static const uint8_t D0   = 16;
static const uint8_t D1   = 5;
static const uint8_t D2   = 4;
static const uint8_t D3   = 0;
static const uint8_t D4   = 2;
static const uint8_t D5   = 14;
static const uint8_t D6   = 12;
static const uint8_t D7   = 13;
static const uint8_t D8   = 15;
static const uint8_t RX   = 3;
static const uint8_t TX   = 1;
#endif /* Pins_Arduino_h */
So my question is... is this pin_mapping.h fully compatible with Wemos d1 mini ?
