- Tue May 30, 2017 7:04 am
#66507
i have connected pull ups to tx and rx pins
which is interfaced to atmega8 SMD controller
and atmega controls the relays.
i am using 5V 1Amp SMPS supply to contol both things including relays connected
readings i have obsereved : when connected all relays and powered on complete kit consums current nearly 800-980 mA
if i only connect esp with atmega8 without any relay then it consumes 90 mA
here only atmega connected consumes 20-25 mA
I assuming that either ESP is not getting power properly or any issue in smps itself
i have implemented deep sleep but drawback is it restarts the complete program which causes loss of configurations
now im wondering if there is any method which i can use to lower power consumtion of esp either by reduing power of RF or any other method. I can no tdirectly make ESP shut for sleeping , it has to be online through out day , becasue for my hom eautomation task it has to be onlin for long day
any suggestions?
temprature noted is 44 C but as time oasses it increased to 55 C. ???
