I have a ESP8266 WsMOS D1 module:-
https://www.iotstarters.com/coding-the- ... duino-ide/
Unlike almost everybody here I would like to interface it directly through the UART Rx and Tx pins.
Hitting the reset always seem to return garbage indication I don't have the correct baud rate
I see numbers all over the map on web sites as to the default baud rate. None seem to work for me.
Two questions:-
1. What is the correct baud rate for this module (right out of the box - unaltered).
2. With a power input of 5V can I run Rx and Tx from a 5v supply UART (Z8035)
Thanks in advance for help
John Monahan
