- Tue Jul 25, 2017 8:14 am
#68551
I built a PCB ardound Esp8266. the circuit is as below. I am using an FTDI adaptor to upload code to the board. I am able to upload the code to the esp8266. To put the esp in bootload mode i first press switch 2(the led on gpio 0 turns on ) then while holding switch 2 i press switch 1 (the blue led on the esp blinks for once) then i leave the switch2 and then the switch 1 and the led at gpio0 is now faintly lit. Now i upload the sketch using arduino. I get the upload done message. All good. I uploaded i code that blinks the gpio0 LED. It works like charm.
But when i burn any other code that uses wifi capabilities. there is a continuous reset message
ets Jan 8 2013,rst cause:4, boot mode:(3,6)
wdt reset
tail 8
chksum 0x2d
csum 0x2d
v6000001c
~ld
Please help. There is no issue due to supply as i have tested with a programable DC powersupply that can deliver upto 5A
