By UniqueIdentifier
#45510 Lots of great information on the forum here. Thank you. However, I've only been able to find a few bits and pieces so, here are my questions if anyone could spare some time to help
1) Does the NodeMCU v2 have an onboard LM that will accept anything up to 9v on the VIN or is it just 5V ? LM33
2) Could I use a 9V battery (or a battery pack) and a V-23V to 3.3V DC-DC Step-Down buck module?
http://www.ebay.com/itm/2A-DC-5V-23V-to ... 1667714648
Is this the best option?
3) Is anyone familar with using 2 AA batteries and a sleep timer and what type of lifetime do you get from your module. I don't mind changing the batteries once a month if it means an easy/cheap solution
Many thanks
By UniqueIdentifier
#45511 For reference, I looked through this rather large thread with many great ideas.
viewtopic.php?f=13&t=577&start=24
I don't know much about power, I'm just hoping to get a couple of months out of the temperature sensor.
Was thinking the the item below is nice and easy for 5V or maybe a 9V battery. Not sure about if it's the most efficient but it looks easy to solder. The other ones mentioned look like chips (SMD?) and much more complicated.
Any recommendations for an easy sub $5 solution with readily accessible parts (AA, 9V batteries)
By UniqueIdentifier
#45512 After a bunch of reading.
I'm thinking to go with a 3 x AA battery pack and a LD1117-3.3 voltage regulator to make sure I don't spike and burn out the ESPP
Will this setup up fully utilize the batteries such as rechargables? I've ready elsewhere that others were getting only 30 minutes on batteries but i'm not clear why.
