By erik2005
#9087 Big thanks to pvvx & CHARTS,
with update to Devkit 1.08 and pvvx- yesterdays update Webbase it works fine.
So no need to change USE_OPTIMIZE_PRINTF or other stuff-
it just compiles out of the box.
BIG THANKS :!: :mrgreen:
pvvx wrote:Hello 'erik2005'.
I am using re-installed the devkit v1.0.7:
http://programs74.ru/get.php?file=Espre ... 8266DevKit (Espressif-ESP8266-DevKit-v1.0.7-x86.exe)
Code: Select allAR .output/eagle/debug/lib/libweb.a
c:/Espressif/xtensa-lx106-elf/bin/xtensa-lx106-elf-ar: creating .output/eagle/debug/lib/libweb.a
AR .output/eagle/debug/lib/libdriver.a
c:/Espressif/xtensa-lx106-elf/bin/xtensa-lx106-elf-ar: creating .output/eagle/debug/lib/libdriver.a
mingw32-make[1]: Leaving directory 'E:/ESP8266/workspace/Web_base/driver'
LD .output/eagle/debug/image/eagle.app.v6.out
FW ./bin/0x00000.bin + ./bin/0x40000.bin
No warning and "error: expected '=', ',', ';', 'asm' or '__attribute__' before 'ICACHE_RODATA_ATTR'"
By pvvx
#9098 esptool.py and esptool.exe has an error. Erased size area flash of more than records.
Added: wifi.power, wifi.noise, sys.rst, sys.sleep.old
<noisefloor>-95</noisefloor>
<power>2137</power>
<cur_start_reset_pin>1</cur_start_reset_pin> Start occurred on reset pin (=1) or sh_pd (=0)
<old_deep_sleep_option>0</old_deep_sleep_option> The last setting deep_sleep (when you reset the power RTC and first start undefined)
http://192.168.4.1/web.cgi?hexdmpb0x40200000=0x1000 - works without fsdisk (without recording WEBFiles.bin)
By pvvx
#9758 Added:
Test upload small WAV from ADC.
Test Sigma Delta OUT (any pins):
/web.cgi?gpio13.sgs=0..0xFF - Start Sigma Delta OUT
/web.cgi?gpio13.sgn=0..0xFF new sqwave
/web.cgi?gpio13.sgc=0.. stop and set default (SDK) function pin
