btidey wrote:Original post says that external pull down didn't work. That sounds strange to me.
I find that pull ups are around 36K as measured on an ESP-12. An external pull down of 3.3K gives a default voltage of 0.27V before the sense of the pin is defined which is well below threshold turn on of any relay driver.
This is borne out by check measurements I took. I also checked with a scope and there were no unexpected transients.
It all depends on the design of the relay driver. If it is a transistor with only a resistor in series with the base (no resistor to ground) then you could have the transistor turn on. If there was a low value resistance to ground then it should effectively short out the current from the pull ups. As I said, it depends on the way the relay driver was designed.
