nicoverduin wrote:Actually I didfinally:
Dip switch settings (seen with the antenna connector top-right):
Dip switch 1 (left)
1 - Off
2 - Off
3 - On connects serial to USB serial (Tx)
4 - Off
5 - On connects Serial to USB serial (Rx)
6 - Off
Dip switch 2 (right)
1 - Off
2 - Off
3 - On connects CH_PD to 3.3V
4 - Off
5 - Off
6 - Off
Interesting. To start with I was trying to hopefully just access the ESP8266-1 serially. My inital Dip switch settings for the left side were 4 and 6 on and the remainder off. With that setup I can see some of the inital AT command occuring from the board;
AT+CWMODE=2
AT+CWSAP="ESP8266","0123456789",11,3
AT+RST
AT+CIPMUX=1
AT+CIPSERVER=1,5000
But cannot enter commands etc.
I have the ESP8266-1 module so I need an interface board. With the main board in the same position my interface board (2 times 2 x 4 headers) is plugged in with the female 2 x 4 on the left side. The ESP8266-module is oriented to the left. Don't ask me why but it works
Assuming you mean to have it oriented like this:
https://www.dropbox.com/s/kgjsqj7dnpo2m ... 5.jpg?dl=0
This is pure experimental (search & discover) . But it works..... As for all those other functionalities.... You probably need one of those other modules.....
Bottom line.... The board works... The quality is crap... some of the tactile buttons need replacement.... Ther was a big solder blob on the board....[/quote]
I agree the board is low quality. I have a feeling my ESP8266 is damaged (the box was crushed in shipment).
