By Squonk
#956
wififofum wrote:
jonsmirl wrote:I believe this is the manufacturer.
http://www.ai-thinker.com/
Maybe someone speaks English there.
The label implies the module has an external PA. That will help a lot with range. But it will make passing FCC much harder.
esp8266 specs wrote:high power PA capable of delivering +25dBm (peak)
If you look at the drawings there are no additional IC footprints.
I agree:
Despite the fact that only the bottom layer pads are shown, the top layer silkscreen and pin number are also displayed. From this you can see that there are only 3 large components and 8 small passive ones onboard: The one labeled "33" is the ESP8266, the 8-pin SOIP is of course the SPI Flash chip, and the 4-pin one is the crystal (with only 1 stray cap, grrr...), so no PA here.
But as the whole shield is a joke, the "PA +25 dBm" text is just another marketing thing :roll:
By Squonk
#957
ps2chiper wrote:Yes, I have experience with CTS labs in Guangzhou. They handle the FCC 15b testing and fcc id for us.
What is the link with the OP?
Wrong topic?
By wififofum
#958
Squonk wrote:Despite the fact that only the bottom layer pads are shown, the top layer silkscreen and pin number are also displayed. From this you can see that there are only 3 large components and 8 small passive ones onboard: The one labeled "33" is the ESP8266, the 8-pin SOIP is of course the SPI Flash chip, and the 4-pin one is the crystal (with only 1 stray cap, grrr...), so no PA here.
In fact the layout is almost identical to ESP-04. Would like to see this with a PCB antenna and/or u.fl and real FCC approval.
