By jertcen
#33332
shoelessone wrote:OK, so, is there some documentation regarding "best practices" and the regulators around the regulator?
I looked at the data sheet and they have a 10uF before the regulator and 100uF after.
I'm wondering what I should do. 100uF after and .1uF before? 100uF and .1uF before and after?
I feel like i"m just randomly putting capacitors everywhere...
Thoughts?
Here is something to read, although I'm sure there are many other and/or better sources of info out there:
http://www.analog.com/media/en/training ... MT-101.pdf
By Barnabybear
#33344
Thoughts?
Hi, the two capacitors after the regulator are for two different reasons (as close to the ESP power pins as possable).
100uF is to act as a store or reserve to give the regulator time to catch up with the demand when the ESP transmits. This is normaly an electrolitic type and only needs to be 6 or 10V rated.
0.1uF is to remove any spikes or noise on the supply that may affect the ESP. This is normaly a ceramic or tantalum type.
The regulator manufacturer may specify a capacitor before. This is usally an electrolitic type and again acts as a reserve when the regulator demand increases.
