Of the 3 resistors on the bottom edge, the middle one is supposed to be have 0 Ohm (dead short). It in series with the supply pin and supposed to be removed, if you mount a voltage regulator on the back. Some boards have a 10k resistor like the other 2 mounted there. You can fix the board if you remove the resistor an bridge the pins with a blob of solder or piece of wire.
