Like I said, make sure the code is reading back the same raw values and calibration values for both the ESP8266 and the Arduino, then you can know for sure if it's the code that converts it to a degree C value.
Or just add this and run the function on both, if it doesn't return the same thing, then its the conversion code.
float BME280::readTest( void )
int32_t adc_T = 0x00AB1234; //fixed test value
//By datasheet, calibrate
int64_t var1, var2;
var1 = ((((adc_T>>3) - ((int32_t)calibration.dig_T1<<1))) * ((int32_t)calibration.dig_T2)) >> 11;
var2 = (((((adc_T>>4) - ((int32_t)calibration.dig_T1)) * ((adc_T>>4) - ((int32_t)calibration.dig_T1))) >> 12) *
((int32_t)calibration.dig_T3)) >> 14;
t_fine = var1 + var2;
float output = (t_fine * 5 + 128) >> 8;
output = output / 100;
return output;
