haroldjclements wrote:I am have tried with both a CP2102 USB to UART TTL
Harold Clements
It's getting more and more difficult to give some sensible advice, considering al the tests you have done.
This is my last shot:
- use the CP2102 and "jiggle" the serial input line on and off to the 3.3V
- some weird characters should appear in your serial terminal. If you see NO weird chars then set the baud rate to a low rate, like 300 or 1200. You MUST see weird characters in the terminal!
Testing that the ESP does output on the TX line can be done by using an oscilloscope, but not many us have access to one. You COULD connect an LED with a serial resistor to the TX line to be absolutely sure that the signal to the Blue LED also reaches the TX connector pin.
That's about all the inspiration I can give you.
