By hdrut
#14413
pvvx wrote:ADC uses 14 bits. The maximum sampling frequency 45..50us (20..22kHz).
Hi Victor. How do you know the ADC uses 14bits? I don't understand the manipulations on the ADC... Can you explain a little? Thanks!
By CptanPanic
#16710 What is the limiting factor to sample at 10khz? Ideally I would like to be able to sample at 40khz in order to detect frequencies up to 20khz. I'm assuming the original 10khz sampling is with running at 80Mhz?
By CptanPanic
#17166 This is what Esprissif said on twitter when I asked them about sample rate:
John Lee ‏@EspressifSystem May 8
@CptanPanic HW is fast, but software needs processing time. probably 200 Hz is OK.
By kwirbx
#30002 For the esp-03 is the TOUT just not broken out? I'd have to access it by directly soldering onto the IC?
