- Fri Dec 04, 2015 9:31 pm
#35686
For now I'm not even getting an AT response from my esp-05 modules. But yeah, if the existing AT firmware or the firmware of my choosing is more than 50%/256k then its a problem.
But if the modules did support OTA, and no longer does, it sounds more like the remote server changed. But I'll see what files they ask for, if any, when I get to talk to them.
Edit:
Turns out there is a large variance in the current draw between modules; had to move away from my usb supply to run some of the modules.
+GMR
AT version:0.25.0.0(Jun 5 2015 16:27:16)
SDK version:1.1.1
Ai-Thinker Technology Co. Ltd.
Jun 23 2015 23:23:50
+CIUPDATE
+CIPUPDATE:1
+CIPUPDATE:2
+CIPUPDATE:3
+CIPUPDATE:4
ERROR
And my http proxy caught this:
request: "GET /ota/device/at/rom/v1/?is_format_simple=true HTTP/1.0"
host: "service.vowstar.net"
request: "GET /ota/device/at/rom/v1/?action=download_rom&version=20150419141355&filename=user2.bin HTTP/1.1"
So despite that, it turns out even the most minimal OTA update examples are around 240-250k so no point with 512k flash.
Update: Some more research shows that my -05's have 1Mbit flash, but the cloud update sepeate the flash into two parts, user1.bin and user2.bin. And the Arduino IDE is not able to produce compatible flash images for either partition. So for me the solution is a $6 soic clip and spi flash programmer, and one-time flash it directly with SPI and use Arduino over the air updates. I'll report back if it works as planned. Part of the reason, is then I also have the soic clip and programmer if i replace the flash chips with 4 or 8M later.
