- Sun Nov 08, 2015 8:35 pm
#33507
UPDATE: So this is where I am at with the project. Again, it's not much of an excuse, but I have such limited time to work on this I am always feeling like it is taking too long. But, in fact, I am learning quite a bit as it goes...and it goes pretty well...I think.
The RTC is an MCP79410. Off the shelf and very cheap. Earlier in the thread, I posted a picture of the home brewed board, and the schematic I used is straight from an application note (AN1365, appendix B). Really, the only differences are the values of a few components. I used 2.2k pullups on the I2C lines because that is what I had. Also, the RTC is the *only* device that will have pullups. Looking at my notes, I ended up with a 4.7K instead of 10K resistor and for the diode I used a BAT43. The caps on the crystal that I used are 10 pf because that is what I saw used in AN1355. The RTC is working well and I am sure that there are others that would also work well. I like soldering my own boards sometimes, so I went this way instead of using one of the DS boards that are ubiquitous.
Software for the RTC right now is my own writing. I couldn't find a full blown library and I really didn't look too hard. From the MCP79410 data sheet I could figure out what I needed to set the time, set an interrupt alarm and clear it. There is admittedly more on this chip and I may get to that stuff at some time.
The sensors worked out pretty well. I am using an ESP8266-11 - not a lot of GPIO on that one. So, GPIO0 and GPIO2 serve as SCL and SDA for the I2C. The ESP8266Arduino interface is working out very well.
For the temp and humidity, I already had interfaced an HTU21D on a Galileo so I used that board. The software for that is taken almost completely from the public domain (beerware actually) posted by Nathan Seidle at Sparkfun.
For the light intensity, I used a BH1750 - again an I2C device that I had previously used. I actually did write some simple code because the examples I found, and there are many out there, did not use the highest resolution. Nevertheless, it was pretty trivial.
I have nothing against Thingspeak, but it does not interest me. I want the ESP8266 to log on to my server, send the packet and power off. I want my server (right now working with a WIN7 implementation) to be listening all the time and log the packets. My knowledge of Visual Studio (VB etc..) is weak and archaic. But it was relatively easy to use examples from MSDN to work up a simple TCP listener and to make matters very simple, right now the code writes the packets to a file - which I can process as I see fit. The simple text file ends up looking like this:
11,8,2015,9,42,0,7,23.44,37.96,63.75
11,8,2015,9,43,0,7,23.44,38.13,63.75
11,8,2015,9,44,0,7,23.46,37.88,62.50
11,8,2015,9,45,0,7,23.47,37.69,62.92
11,8,2015,9,46,0,7,23.49,37.96,62.92
11,8,2015,9,47,0,7,23.50,38.11,81.67
11,8,2015,9,48,0,7,23.53,38.23,214.17
11,8,2015,9,49,0,7,23.54,38.01,217.92
11,8,2015,9,50,0,7,23.55,38.00,217.92
11,8,2015,9,51,0,7,23.55,37.83,218.75
11,8,2015,9,52,0,7,23.56,37.82,219.58
11,8,2015,9,53,0,7,23.58,37.78,218.33
11,8,2015,9,54,0,7,23.59,37.89,218.75
11,8,2015,9,55,0,7,23.60,37.98,217.92
11,8,2015,9,56,0,7,23.61,37.91,216.67
11,8,2015,9,57,0,7,23.61,37.69,215.83
11,8,2015,9,58,0,7,23.62,37.62,215.83
11,8,2015,9,59,0,7,23.64,37.69,215.42
11,8,2015,10,0,0,7,23.65,37.54,214.58
11,8,2015,10,1,0,7,23.66,37.59,214.17
On to the packet itself. The figure shows the approach I am taking right now although it may change. Very simple and straightforward - comma delimited values.
For testing, I am running 1 minute intervals although I am finding out that my ISP, AntiVir and or Router are not crazy about 100s of logins in a short period of time, but I am pretty sure that it has nothing to do with the ESP code (a longer explanation is required but it has been looked into). Speaking of that, generating a simple TCP client for this application is pretty much like all the applications that you see. Because I am powering off the ESP after sending, I am not burdened by maintenance cleanup. Of course, it has to power down if it can't log in and send the packet (can't sit there forever) for some reason, but that was trivial and it is so far so reliable that I had to turn off the listener for testing.
That's where I am at right now, I will keep all updated and I am fine sharing the code on any of this - especially after I "unslop" it
Just ask.
Cheers,
DrG
edited to include the correct jpg
