thakshak wrote:i'm a beginner.. pls bear with me..
why u use 100uF tantalum capacitors in-out to LDO
in other circuits i have seen someone using in-100uF and out-1000uF,
another using two capacitors(ceramic) to in and out of LDO as shown in below image...
another in-4.7uF and out-10uF,
is there any difference between types(tantalum ceramic electrolytic etc) of caps we use...?
and what values of caps are best to use for esp-12..?
thanks..
The caps i used are what i had laying around. And these work fine with my board. Though you can always choose to put bigger caps on there, might you need it.
Tantalum capacitors are more precize and efficient than normal caps. But here goes the same, you may change them for normal caps.
Usually, the bigger the cap value, the bigger power fluctuations it can filter.
ESP-07 + DIY breadboard adapter
