- Wed May 10, 2017 5:19 am
#65796
One thing that could be wrong is that you have used a 470uF capacitor.
The capacitor is there for decoupling, i.e. for smoothing out the power to the ESP-12 very temporarily.
I assume you have used an electrolytic capacitor? The problem with these in this application is that the parasitic inductance is much higher than for ceramic capacitors which are usually used as decoupling capacitors. The parasitic inductance reduces the ability of the capacitor to smooth out quick variations in power consumption.
If this matters in practice is hard to tell. In some photos of an ESP-12 there seems to be a decoupling capacitor under the hood already, on other photos there is none. If your ESP already has decoupling inside the external decoupling should not matter so much. Some problems could also be caused by long leads to the components. These increase parasitic inductance.
You could try to replace your 470u capacitor with a ceramic one and try to keep the leads as short as possible to the VCC and GND pads on the ESP12.
I hope this helps in your debugging. This seems like a tricky problem to solve.
