ErikLem wrote:(Since all commercial products around are also quite expensive, I'm kind of guessing that measuring co2/voc is just a lot more complicated than temperature or humidity. have a look at this list for instance:
http://www.energycircle.com/guide/guide ... althy-home)
Another option is to use the analog sensors and use an external ADC that supports I2C, such as the ADS1115. This supports 2 differential inputs, or 4 single inputs, and can be controlled over I2C. You'll need a logic level shifter as well - as the ADS range requires 5V. Not hard though. The combination of an ADS1115 board and a logic level shifter should only come to $2-3.
As to the reason for the cost of these devices while I suspect it is more complicated to build such a think, I suspect the reason for the price difference is more to do with quantity - and probably safety concerns as well.
esp8266 otb-iot documentation - https://otb-iot.readthedocs.io/
esp8266 related blog - http://www.packom.net/
