piersfinlayson wrote:And 4MB flash. Very neat looking design.
Thank you! So, you think that the ESP-01S has 4MB flash too?
Explore... Chat... Share...
KevinA wrote:Electrondragon has the -01S it is not FCC but it does have a 25Q80 or 1MB flash $2.40
KevinA wrote:Update: I revisited the ESP8285 module at Electrondragon and found http://www.electrodragon.com/w/ESP8285
They route a grove on a PCB and stick the board into the grove! I'm going for it! this is cheaper than headers or building a castellated PCB, what will happen to the copper pads when/if they are sit by the router?
