By peut
#78115 HI,
You may be able to use the ESP01 by using GPIO 0 and 2.
Using the example, change
Code: Select all#define NOVARX 13
#define NOVATX 12
to
Code: Select all#define NOVARX 0
#define NOVATX 2
You may also want to look at the SDS library at https://github.com/lewapek/sds-dust-sen ... no-library which can be installed by looking for SDS in the Arduino library manager.
That library supports hardware serial, so you can use the "normal"RX and TX pins.
Good luck!
