- Wed Mar 16, 2022 9:15 pm
#93969
kinlougha wrote:Hello Inq720,
The serial chip on the MiniPro was CP2104, not CH340.
You can see that the serial chip respond to the inquiry from the IDE
BN: Carte inconnue
VID: 10C4
PID: EA60
SN: Envoyez un croquis pour l'obtenir
It's not a driver problem.
It's something else between the serial chip and the ESP.
I'm more of a software guy... What is in that output that tells you its a CP2104? I'm not seeing it. I'm sure you're right, I just trying to figure what says CP2104.
I thing it's a hardware problem like bad choice of part on the board or a design flaw, don't forget it's a chinese clone.
I think this is a philosophical question... is there a difference between a Chinese product and a Chinese clone of Chinese product?
Can i be able to bypass the serial chip to upload some firmware on the ESP8266.
I once blew up a CH340 based WeMos and just for curiosity, I de-soldered the ESP8266MOD daughter board off the WeMos motherboard and plugged it into a programmer made for ESP-07s with its own CH340. It worked like a champ. Also, once you get the first Sketch uploaded (that has OTA) on it, from then on, you can do your uploads via WiFi.
