- Fri May 08, 2015 11:34 pm
#16951
Can someone help.
I'm not an expert with MAKE files - this is the make file used in the "unnofficial" toolset for programming in Windows with Eclipse.. uaing TUANPMs MQTT code.
I now find that on the ESP-12, my code compiles and runs no problem on ESP-1, ESP-07 and ESP-12 using the API version 0.96.
HOWEVER with later versions 1.0 and 1.01 of the SDK the code compiles perfectly but will not RUN on the ESP--01 or the ESP-07 - yet it runs perfectly on all three in the earlier compiler.
I'm seeing no size directives in the makefile below and I can't figure out how to add one in, to make my code work with the later compiler.
Can anyone help?
# Changelog
# Changed the variables to include the header file directory
# Added global var for the XTENSA tool root
# This make file still needs some work.
# Output directors to store intermediate compiled files
# relative to the project directory
BUILD_BASE = build
FW_BASE = firmware
FLAVOR = release
#FLAVOR = debug
# Base directory for the compiler
XTENSA_TOOLS_ROOT ?= c:/Espressif/xtensa-lx106-elf/bin
# base directory of the ESP8266 SDK package, absolute
SDK_BASE ?= c:/Espressif/ESP8266_SDK_1.01
#Esptool.py path and port
PYTHON ?= C:\Python27\python.exe
ESPTOOL ?= c:\Espressif\utils\esptool.py
ESPPORT ?= COM6
# name for the target project
TARGET = app
# which modules (subdirectories) of the project to include in compiling
MODULES = driver mqtt user
EXTRA_INCDIR = include $(SDK_BASE)/../include
# libraries used in this project, mainly provided by the SDK
LIBS = c gcc hal phy pp net80211 lwip wpa upgrade main ssl
# compiler flags using during compilation of source files
CFLAGS = -Os -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -D__ets__ -DICACHE_FLASH
# linker flags used to generate the main object file
LDFLAGS = -nostdlib -Wl,--no-check-sections -u call_user_start -Wl,-static
ifeq ($(FLAVOR),debug)
CFLAGS += -g -O0
LDFLAGS += -g -O0
endif
ifeq ($(FLAVOR),release)
CFLAGS += -g -O2
LDFLAGS += -g -O2
endif
# linker script used for the above linkier step
LD_SCRIPT = eagle.app.v6.ld
# various paths from the SDK used in this project
SDK_LIBDIR = lib
SDK_LDDIR = ld
SDK_INCDIR = include include/json
# we create two different files for uploading into the flash
# these are the names and options to generate them
FW_FILE_1 = 0x00000
FW_FILE_1_ARGS = -bo $@ -bs .text -bs .data -bs .rodata -bc -ec
FW_FILE_2 = 0x40000
FW_FILE_2_ARGS = -es .irom0.text $@ -ec
# select which tools to use as compiler, librarian and linker
CC := $(XTENSA_TOOLS_ROOT)/xtensa-lx106-elf-gcc
AR := $(XTENSA_TOOLS_ROOT)/xtensa-lx106-elf-ar
LD := $(XTENSA_TOOLS_ROOT)/xtensa-lx106-elf-gcc
#### no user configurable options below here
FW_TOOL ?= $(XTENSA_TOOLS_ROOT)/esptool
SRC_DIR := $(MODULES)
BUILD_DIR := $(addprefix $(BUILD_BASE)/,$(MODULES))
SDK_LIBDIR := $(addprefix $(SDK_BASE)/,$(SDK_LIBDIR))
SDK_INCDIR := $(addprefix -I$(SDK_BASE)/,$(SDK_INCDIR))
SRC := $(foreach sdir,$(SRC_DIR),$(wildcard $(sdir)/*.c))
OBJ := $(patsubst %.c,$(BUILD_BASE)/%.o,$(SRC))
LIBS := $(addprefix -l,$(LIBS))
APP_AR := $(addprefix $(BUILD_BASE)/,$(TARGET)_app.a)
TARGET_OUT := $(addprefix $(BUILD_BASE)/,$(TARGET).out)
LD_SCRIPT := $(addprefix -T$(SDK_BASE)/$(SDK_LDDIR)/,$(LD_SCRIPT))
INCDIR := $(addprefix -I,$(SRC_DIR))
EXTRA_INCDIR := $(addprefix -I,$(EXTRA_INCDIR))
MODULE_INCDIR := $(addsuffix /include,$(INCDIR))
FW_FILE_1 := $(addprefix $(FW_BASE)/,$(FW_FILE_1).bin)
FW_FILE_2 := $(addprefix $(FW_BASE)/,$(FW_FILE_2).bin)
BLANKER := $(addprefix $(SDK_BASE)/,bin/blank.bin)
V ?= $(VERBOSE)
ifeq ("$(V)","1")
Q :=
vecho := @true
Q := @
vecho := @echo
endif
vpath %.c $(SRC_DIR)
define compile-objects
$1/%.o: %.c
$(vecho) "CC $$<"
$(Q) $(CC) $(INCDIR) $(MODULE_INCDIR) $(EXTRA_INCDIR) $(SDK_INCDIR) $(CFLAGS) -c $$< -o $$@
endef
.PHONY: all checkdirs clean
all: checkdirs $(TARGET_OUT) $(FW_FILE_1) $(FW_FILE_2)
$(FW_FILE_1): $(TARGET_OUT)
$(vecho) "FW $@"
$(Q) $(FW_TOOL) -eo $(TARGET_OUT) $(FW_FILE_1_ARGS)
$(FW_FILE_2): $(TARGET_OUT)
$(vecho) "FW $@"
$(Q) $(FW_TOOL) -eo $(TARGET_OUT) $(FW_FILE_2_ARGS)
$(TARGET_OUT): $(APP_AR)
$(vecho) "LD $@"
$(Q) $(LD) -L$(SDK_LIBDIR) $(LD_SCRIPT) $(LDFLAGS) -Wl,--start-group $(LIBS) $(APP_AR) -Wl,--end-group -o $@
$(APP_AR): $(OBJ)
$(vecho) "AR $@"
$(Q) $(AR) cru $@ $^
checkdirs: $(BUILD_DIR) $(FW_BASE)
$(BUILD_DIR):
$(Q) mkdir -p $@
firmware:
$(Q) mkdir -p $@
flash: firmware/0x00000.bin firmware/0x40000.bin
$(PYTHON) $(ESPTOOL) -p $(ESPPORT) write_flash 0x00000 firmware/0x00000.bin 0x3C000 $(BLANKER) 0x40000 firmware/0x40000.bin
blank512k: firmware/0x00000.bin firmware/0x40000.bin
$(PYTHON) $(ESPTOOL) -p $(ESPPORT) write_flash 0x00000 blank/blank512k.bin
test: flash
screen $(ESPPORT) 115200
rebuild: clean all
clean:
$(Q) rm -f $(APP_AR)
$(Q) rm -f $(TARGET_OUT)
$(Q) rm -rf $(BUILD_DIR)
$(Q) rm -rf $(BUILD_BASE)
$(Q) rm -f $(FW_FILE_1)
$(Q) rm -f $(FW_FILE_2)
$(Q) rm -rf $(FW_BASE)
$(foreach bdir,$(BUILD_DIR),$(eval $(call compile-objects,$(bdir))))
