I am using 10K resistors at the moment. I have read somewhere that it would work with resistor values >= 33K Ohm. Is that right? Or is there another way to get this done?
Thanks for the help!
If your mosfets need to be grounded at startup and the GPIOs needs to be pulled-up, then you need a second stage of N-mosfets to invert the logic states (or use P-channel mosfets).
Has anyone seen a resource like that?
