Has anyone else tipps on what to use to get the esp running and stable?
How exactly can I use the adc pin?
Ah and can someone explain why 16 and RST have to be wired together for beeing able to use sleep? And do they also have to be pulled high?
Explore... Chat... Share...
GeorgeIoak wrote:I hope this helps.
GeorgeIoak wrote:Double check your capacitor values you've stated, you have some "uF" and "nF" mixed up. Since the ESP modules don't have much onboard capacitance and the current draw can drastically change from very little to 200-300mA it is best to have a "reservoir" cap on the Vcc rail placed close to the module. This will help prevent voltage droop when the large current spikes happen.
