By HermannSW
#19433 Just saw what GPIO15 is about, from:
https://github.com/esp8266/esp8266-wiki/wiki/Boot-Process
GPIO15 being HIGH on startup selects boot from SD card, so it should be connected to GND normally (on startup):
https://drive.google.com/file/d/0ByLNRzaQc0jPV0xaektpdFFoMGs/edit
Hermann.
By GeorgeIoak
#19436 Yes, you are correct, you should use a resistor to pull GPIO15 to GND. Depending on what you are doing with the LED on GPIO2 you might want to adjust that resistor value. I don't recall the drive strength of the ESP8266 but putting 10mA through the LED is usually more than enough to make it bright. Just use Ohms law (V=IR), where V in this case is 3.3-Vf and Vf is the forward voltage of the LED you're using.
