https://github.com/reischle
http://www.areresearch.net/
http://youtube.com/AReResearch
Explore... Chat... Share...
It's guaranteed that RESET and CHIP_EN pins are inputs when the ESP8266 is first powered up, so as long as the user code doesn't ever make them outputs, shorting them to high shouldn't cause a problem.
OFF: CHIP_PD pin is low. The RTC is disabled. All registers are cleared.
