elac wrote:That step down power supply uses about 15mA - 18mA quiescent current.
Where did you get that number? LM2596 modules will use that much, but the MP2307 datasheet states 1.3mA as typical supply current.
Explore... Chat... Share...
lethe wrote:elac wrote:That step down power supply uses about 15mA - 18mA quiescent current.
elac wrote:If other devices will be powered from the same 6V supply, put a diode in series with the positive IN of the module and a 470 uF cap across the INPUT of the module.
