EN and CH_PD is the same pin, it only depends of the modules silkscreen.
Thanks it seems like it is labeled differently on the aliexpress site.
So which pins do i actually have to pull up or down if i want to enable the chip to execute its program or to flash it with a new program?
According to this table on github:
https://github.com/esp8266/esp8266-wiki ... boot-modes
I have to set GPIO15 & GPIO0 on GND and GPIO02 High to download code from uart (which means programming it, for example with the arduino IDE, doesn't it?)
And just to execute the program i have to set GPIO015 on GND, GPIO0and GPIO02 High.
Is this correct for the ESP-12(F)?
GPIO0 pullup for normal execute mode while LOW for entering UpLoad/Programming mode during reset or power up.
So basically i don't even need a jumper for GPIO15 because it is LOW all the time?
Just another question: I will need a 10k resistor for every pin you just mentioned?
