#define led 2
noInterrupts();
pinMode(led, OUTPUT);
while (true) {
digitalWrite(led, LOW);
digitalWrite(led, HIGH);
It gives me a 1.1MHz squre wave at GPIO2 with a frequency drop at about half the frequency every almost 3 seconds
But why are you trying to block interrupts ? Because in this case, even if WiFi tasks partially running, you won't get a working WiFi.
If it is simply to have a stable waveform, maybe you should attach a separate MCU to do that, such AVR, or even STM32.
I only wanted to see how the firmware has been implemented
and do a hardware benchmark, as well as seeing how good it is in real time tasks.
Knowing that there is a sort of wifi interrupt is enough,
but as i don't need it, is there a way to deactivate it?
