By projectgus
#22200 I've been using the 'ScratchABit' tool by @pfalcon a bit to analyze the RTOS binary libraries.
EDIT: What I wrote here before was _not_ the right way to add plugins to scratchabit. Here's what I now understand to be the correct way:
... then you can run
Code: Select allscratchabit.py esp8266.def
to run an interactive disassembler session, annotate symbols, etc. It's not the most full featured dissassembler (at least not yet) but it's 100x better than using objdump and text editors.
By projectgus
#22201 There are also a couple of other interesting RE projects out there. There's a wiki and mailing list here:
http://esp8266-re.foogod.com/w/index.ph ... ering_Wiki
The most interesting bit at the moment is a bit buried, that is some analysis of the RTOS SDK startup code here:
http://esp8266-re.foogod.com/w/index.ph ... K_0.9.9%29
And the same person who created the wiki has their own disassembly tool (that I haven't yet tried) here. It's non-interactive, so I'm guessing similar to objdump but with more features:
https://bitbucket.org/foogod/xtobjdis
By hreintke
#22243 Thanks cal,
Appreciate your help, it works like intended and I was able with your explanation to get going.
Tricky part was the real understanding of the translation from
Code: Select all4020bf8a:   c40000           extui   a0, a0, 0, 13
4020bf8d:   3ffe87           bbsi   a14, 24, 4020bfd0 <divide+0x34>
To the address
Code: Select all3ffe87c4
Due to the (I think) disassembling sometimes "reversing" the little endian mode and display in big edian.
Solved that by looking at the objdump -s of the irom0.text ouput.
Limited the output of all -s to objdump -s -j.rodata and now up to scanning/searching the files automatic.
Herman
