bowlman42 wrote:Now switching mains without a problem using a 2A solid state relay.
Did you also try a 'normal relay? Solid State Relay's do not create EMP so this won't be picked up by the RST line.
Explore... Chat... Share...
Sweetpants wrote:bowlman42 wrote:Now switching mains without a problem using a 2A solid state relay.
kerpz wrote:@Sweetpants since you put a decoupling at rst near the chip you don't need to cut the line toward the header pin, and you can still use the rst function. that 100nF is a low pass filter that removes high freq noise before reaching the chip.
