By schufti
#49143 The short between sda and scl is unfortunate but can't be the reason for a fried regulator ...
The vias for rst and chpd are very unfavourably placed, much to close to other solderpads of the esp.
Most likely you get a short between the via for chpd and gpio15 solderpad.
Also the via middle under the esp is prone to contact vias on the esp itself.
By lethe
#49150 Probably unrelated to the regulator issue as well: the VCC trace on the top side runs dangerously close to the data pin of the lower left port, same goes for the via on the top left of the bottom side image.
You should run a design rules check in your PCB editor and fix all clearance issues reported.
If you have another run at the board anyway, you should also use thicker traces for VCC and GND.
Also if you rotate all those I2C and data port pin headers by 90°, you will have a much easier time connecting them since all pins with the same signals will be adjacent.
By martinayotte
#49151
lethe wrote:If you have another run at the board anyway, you should also use thicker traces for VCC and GND.
Absolutely ! It will avoid many power issue that ESP surge can cause, makeing sure decoupling caps are as near as possible to the module.
lethe wrote:Also if you rotate all those I2C and data port pin headers by 90°, you will have a much easier time connecting them since all pins with the same signals will be adjacent.
Yes ! Of course ! Especially if layers count are limited.
