rudy wrote:spy king wrote:rudy wrote:I would put a lot more capacitance on VCC. at least 100uF but preferably higher.
I am a bit confused here. In my understanding, the ceramic 100nF serves as a decoupling cap correct?
If I already have a reservoir cap from the supply section, do I still require another reservoir near the module?
And how much charge is available from a .1uF cap? Where did you get the idea that that was sufficient? Yes a decent sized cap in your power supply is good to have but how close will it be?
The ESP8266 (and many other devices like this) have some high current draws at time. They will cause a dip in the supply voltage. And what we need to do is to make that dip/spike smaller than what the ESP8266 and the flash chip will consider as a disruption.
One thing you should remember. Every wire is an inductor. Every trace is an inductor. Every via has inductance. For many things we can ignore these but sometime they do matter.
Thanks for the clear explanation, makes sense. Sorry for the somewhat basic questions, but now I know what to read up about, and determine the right way to determine what value of buffer capacitance to provide. Lots to learn for me!
