- Tue Oct 06, 2020 8:31 am
#89034
Thx for the late reply and thx for all the suggestions!
A few comments:
All these breakout boards: That's not what I'm looking for, as the ESP is soldered to that. I want to have it easily removeable on the minimal space.
The esp201 is an interesting thing, because it at least has 2.54mm pitch pin headers, instead of 2. So I could at least mount it to a PCB...
OTA: Yes, I need to do that one day, but all the comments about still being able to have it easily removeable in case of a failure stand
I'm now going with simple 2mm Dupont connectors: Luckily the 2mm pin headers I stick to the ESP-12F are so tight, I don't have to solder them. So I can easily remove them again and instead of soldering cables to these 2mm pin headers (which is absolutely *horrible*), I simply connect them with these Dupont connectors.
* 2P/3P/4P:
https://www.aliexpress.com/item/32494185149.html* 5P/6P/7P:
https://www.aliexpress.com/item/32496148205.html* 8P:
https://www.aliexpress.com/item/32493962949.htmlWasn't easy to actually find 2mm pitch Dupont headers, was the only seller I found that sells them...
With this, I can have the ESP "flying around" in the cases, next to the PCB with the battery socket, some resistors, transistors, capacitors and what else I need for a project. And I can easily remove it by removing the Dupont connectors and then removing the pin headers and stick the ESP onto my devboard I have linked in my original post.
Hope this will help other strange people like me
Thanks again for all the input!
