Manufacturer: e0
Device: 4016
I am not sure how to interpret this. I am thinking that based on the manufacturer, the device code can then be looked up ... but where would one find a list of codes for decoding purposes?
Explore... Chat... Share...
kolban wrote:Manufacturer: e0The device code 0x4016 from manufacturer 0xe0 (WinBond) denotes a 32Mbit (4 megabyte) chip. The chip itself is probably a W25Q32. You can verify the device id in the datasheet:
Device: 4016
uint32_t EspClass::getFlashChipSizeByChipId(void) {
uint32_t chipId = getFlashChipId();
* Chip ID
* 00 - always 00 (Chip ID use only 3 byte)
* 17 - ? looks like 2^xx is size in Byte ? //todo: find docu to this
* 40 - ? may be Speed ? //todo: find docu to this
* C8 - manufacturer ID
switch(chipId) {
// GigaDevice
case 0x1740C8: // GD25Q64B
return (8_MB);
case 0x1640C8: // GD25Q32B
return (4_MB);
case 0x1540C8: // GD25Q16B
return (2_MB);
case 0x1440C8: // GD25Q80
return (1_MB);
case 0x1340C8: // GD25Q40
return (512_kB);
case 0x1240C8: // GD25Q20
return (256_kB);
case 0x1140C8: // GD25Q10
return (128_kB);
case 0x1040C8: // GD25Q12
return (64_kB);
// Winbond
case 0x1640EF: // W25Q32
return (4_MB);
case 0x1540EF: // W25Q16
return (2_MB);
case 0x1440EF: // W25Q80
return (1_MB);
case 0x1340EF: // W25Q40
return (512_kB);
default:
return 0;
uint32_t EspClass::getFlashChipRealSize(void)
return (1 << ((spi_flash_get_id() >> 16) & 0xFF));
