- Sat May 09, 2015 12:14 pm
#17007
jonsmirl wrote:Word back from Espressif on those early sample WROOM modules.
"i think the reason is WROOM-01 (the early versions of it), used DIO flash and not QIO flash."
What is difference between DIO and QIO flash? I have not heard of that before. So I suspect if you replace the flash chip on those early models they will work the way you expect them too.
Moin,
I think its a communication mode d for double someting q for quad.
I think i read that the esp supports different communication modes for flash modules.
If that needs to be programmed it may explain problems with firmwares that are used on qio flas modules
before.
If i remember correctly i saw sio/dio/qio in the data sheet of some flash chips. Maybe just lookup
the one for some.
Just some vague thoughts.
Cal
