Got to say, love the PCB and well done ArnieO for the technical calculations. Great little device presented with this little mosfet. It seems to me that the PCB track thickness has been missed in current calculations here. I would not want to sink 5 amps of current through a PCB track this size. A calculation as follows would be required to ensure PCB track is capable of supplying required current:
The trace width is calculated as follows:
First, the Area is calculated:
Area[mils^2] = (Current[Amps]/(k*(Temp_Rise[deg. C])^b))^(1/c)
Then, the Width is calculated:
Width[mils] = Area[mils^2]/(Thickness[oz]*1.378[mils/oz])
For IPC-2221 internal layers: k = 0.024, b = 0.44, c = 0.725
For IPC-2221 external layers: k = 0.048, b = 0.44, c = 0.725
where k, b, and c are constants resulting from curve fitting to the IPC-2221 curves
It works out for a track of 1 inch in length, 2 oz copper thickness fr4 laminate the width would need to be 1.38mm
Another question I want to ask, is why was the dc module used instead of a 3.3v LDO regulator?
Nice work again well done.
