By clinkme
#4054
villTech wrote:if you can use the gpio as sink driver for led, then you can take away the caps.
Yes, it works right in my config. Just connect led to '+' bus and any GPIO.
Output value=0 to that pin will light the led.
By ucy74
#4068
Well, its not so simple:
Port can be describbed as input or output.
Setting high level on pin configured as input means pull-up.
Setting high level on pin configured sa output means high level and can drive LED.
On the boot GPIO's are configured as inputs.
To drive LED's GPIO's are configured as outputs.
So, if You prepare schematic straight for drive LED's You can have problems to proper reboot chip.
If You play with GPIO good option with capacitors is to set GPIO2 as input an pullup before (expecting) reset chip
