- Tue Nov 10, 2015 9:20 am
#33620
kolban wrote:Have you looked at the NodeMCU devKit board? This has been my "go-to" for a while.
not much use if you want to program an ESP-01 is it? i think the op wants an easier way to program an ESP-01 than a breadboard with a bunch of cables, regulator, uart, button etc.
if you want to keep size, power and cost down and only want to use a couple of GPIO's the ESP-01 is way better than the nodemcu which is massive in comparison and has way too much stuff onboard for battery use.
personally i just made up something myself on perfboard, then i move the ESP-01 between the circuit i'm working on and the programmer board. didn't even bother with a regulator or buttons, as all it will be doing is flashing which is ok being powered from my 3.3v usb uart, its basically a couple of female headers and 6 wires.
