By xtal
#36980 I had a problem on my ESP-13 .... The pin diagram showed multiple grounds and I failed to ground 1 of them .
Work great after I got all the grounds connected...
What are you using to test with Windows , mac, or something else?
By Roypo
#37048 i have the same issue too,
have you solved it yet?
i had some issues with the board the "RXD" and the "TXD" are labeled in the wrong way.
but if you got to the info it is o.k in yours case,
please update if you got something,
thanks
By xtal
#37058
when I power up board I get:
AI-THINKER & VOWSTAR, 2014
SDK version:0.9.2
mode : sta(18:fe:34:a2:89:64) + softAP(1a:fe:34:a2:89:64)
add if0
add if1
dhcp server start:(ip:192.168.4.1,mask:255.255.255.0,gw:192.168.4.1)
bcn 100
Observations:
1> I've never seen the VOWSTAR before,
2> sdk 0.9.2 pretty old sdk unless its keyed to VOWSTAR
3> A server has started 192.168.4.1 Have you tried connecting to it.....
4> since the server is running it could be blocking the serial , or changing baud rate,, just a thought
5> since you see the bootup info the ESP Tx is connected properly , don't know about Rx
Looking at my 12- e Antenna up the top right 2 pins tx,rx, do you have good connection to the pins on the mounting board.
Why not download ESPlorer [need java] and use that for the serial monitor + other...
For Flashing I had good results with ESP FLASH DOWNLOAD TOOL V2.4
